Too many attemps made for this increment
i'm really new for Abaqus.
so i have qustions,i have alredy completed my simulation with off nonlinear.but when i try to use on nonlinear it's show Aborted.how can i fix that? soomeone told me that i have problems with contact,so i try to change contact(interaction) i found nothing. its still Aborted. Any suggestione?
RE: Too many attemps made for this increment
Well, this happened to all of us I guess.
I am not an expert to solve your problem but I can recommend you to play with deactivating the contact just to see if it is the cause of the problem. Maybe you are already aware of that. Another possibility could be to change the size of the elements.
And another possibility is to change the max numbers of attempts.
Not sure if I am ortodox in my language but may be just some ideas can help you.
good luck
n3l3
