material selection of pump
Ladies and Gentlmen
we have corrosion problem with pump used for treated water in industrial area
material of wet pump is carbon steel and cast iron (casing, impellar and shaft)
i want to upgrade material of vertical Aerator Effluent Pump
i am thinking about nonmetallic material or steel lined with PTFE or SS
so please advise if you have experience
RE: material selection of pump
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
Plymouth Tube
