Load combinations for anchorage of pipes with thermal and fluid loads
We are providing supports for pipes with thermal and fluid loads. When applying ASCE 7-05 load combinations, what part of the load combination shall we apply the thermal and fluid reactions.
It is clear where we apply the Gravity and seismic loads but for internal fluid pressures and thermal loads, ASCE is not very clear.
RE: Load combinations for anchorage of pipes with thermal and fluid loads
The California Building Code has a clear definition of F and T which is where the fluid pressure and thermal reactions are to be included.
At minimum, use 2008 ASHRAE Handbook chapter 45 to ensure you are not over stressing the pipe.
It can be challenging to find the proper restraint configuration for piping subject to both seismic and thermal loads.
