How to estimate water flow through a pump with inverter
We have installed an energy saving equipment. Electric frequency is decreased from 50H to 45Hz, and pump discharge pressure is 3.0 kg/cm2.g.
How can we estimate water flow by the current pump condition? Please help me.
Lukman Nulhakiem
http://safety-slogans.net
RE: How to estimate water flow through a pump with inverter
So You mean that you reduced the pump running speed?
If you reduced the pump speed, you can look at the pump curve for different pump speeds. If you don't have the pump curve, you can simply use the affinity law to estimate the flow rate.
Q1/Q2 = N1/N2, H1/H2 = (N1/N2)^2
