Wall Pressure Zones 'a'
I have a building that has a high roof in the SW corner. The overall dimensions are 840' E-W and 1692' N-S. The high roof is 432' E-W and 750' N-S. The high roof starts at the SW corner. The high roof is 72' and the low roof is 38'. Based on the high roof (>60') my 'a' is 10% least horiz dim = .1(840')=84'. So I'm using that for all four main corners of the building. The corners of the high roof that aren't one of the main corners I used the least horiz dim of the high roof and not the overall .1(432')=43.2'. Does it make sense to do that or do I need to be using 84' at the high roof area also.
RE: Wall Pressure Zones 'a'
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
