Issue with SW2010 converting sheet metal to DWG
I have only recently discovered the export to DWG/DXF option in SW2010.
though i am having problems with some of the parts i try to send, it seems to struggle with tangent edges and fillets. the fillets and tangent edges seem to go the opposite way than i have drawn them. has anoyone experienced this and does anyone know a remedy?
thanks in advance
thanks in advance
RE: Issue with SW2010 converting sheet metal to DWG
thanks for your input but i still am having the same issue, i tried teaking what you said in the options but to no avail. this issue it only seems to happen with the more complex of shapes, usually those involving numerous fillets and tangent sketch entities.
Really hard to help without being able to see what you are working with.
Cheers,
Anna Wood
SW2011 SP5, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
thats my first time uploading a file hope it works ok
How are you creating the DXF, and which options are you using?
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." -Scott Adams
i am converting to a dwg and i do it by right clicking the part as shown in the two photos
As far as your screen captures go, use "Alt+Print Screen" instead of just the "Print Screen" key. Doing that only captures the active window.
What SP of 2010 are you currently using?
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
