Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...thank you for the wonderful resource that you have enabled here. It is clear, concise, well maintained and most importantly, helpful..."
Geography
Plastic-specific fasteners, where to buy in smaller quantities
KiwiME (Mechanical)
13 May 12 23:10
Gidday people, from down under in New Zealand.
I design small watertight enclosures (for scientific instrumentation) made typically from machined acetal (Delrin). The best type of fastener to hold these things together are those designed specifically for plastics and have a small (sharp) thread angle with extra space between the threads. The ends are blunt (since the hole is pre-drilled) and some have a tri-lobal shape. Head diameters are twice the nominal thread size and the drive is typically Torx. 2mm and 3mm thread diameter make up are the majority of what I need, pan and flat heads, 6 to 12mm long.
We generally buy around 500 at a time and in the past I've found exactly what I want at McMaster-Carr. However, they are now refusing to sell to us since "discovering" we are not "in America." They even refuse to sell to our US office, citing their wares are "not for export."
So, I'm looking for a less-ignorant, internationally-aware supplier for these sorts of fasteners. Certainly no-one in this country sells these.
Any leads appreciated!
patprimmer (Publican)
14 May 12 1:13
You could try Blackwoods in Sydney Australia.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
HDS (Mechanical)
14 May 12 12:44
Look for plastite screws from camcar.
dgallup (Automotive)
14 May 12 16:37
EJOT makes really good screws for plastics. You will have to figure out where to buy them locally.
Close Box
Join Eng-Tips® Today!
Join Us             Close
