Abaqus - 2d study of a single lap joint
Hello, I started working with Abaqus for a short time, and I'm trying to validate a study (stress analysis, not the failure analysis), based on the following article http://www.tc.faa.gov/its/worldpac/techrpt/ar01-57.pdf
I've done the model, but when i choose the non-linear geometry in step and run the job, abaqus gives me an error "Time increment required is less than the minimum specified". I've run the program several times differently and i can not understand why the results are not correct.
