Joining Two Piece of Glass Filled (30%) Nylon
Hello everyone. I have small personal project that I would like some help on. I need to join two piece of glass filled nylon with not a lot of surface area to work with. The joint needs to withstand 200+ degrees Fahrenheit as well as some impulse energy. My primary question is should I use adhesive or plastic welding to join the two pieces. I have some scarp that I can use for the plastic welding by using a small soldering iron-like hand tool but I would like to know if Devcon Plastic Welder adhesive might give a similar result. Thanks for reading.
RE: Joining Two Piece of Glass Filled (30%) Nylon
It is even more difficult when it is glass filled.
Acrylocyanurates give a reasonable result with a good joint design like if it has dowels or stakes or dovetails and the glue simply holds it in place but mechanical design takes most of the load or if there is a large surface area more in shear than tension.
Ultrasonic welding works well if you have the time and equipment to experiment a bit and get it right. I very much doubt that is your case from what you say.
Concentrated formic acid works well as a solvent glue on unfilled. I can work on glass filled but not so well. It is a moderately dangerous chemical to handle, being the sting in an ants sting.
Dissolving extra unfilled nylon of the same type in the formic before using might help with a glass filled grade as it will act as a filler to prevent the joint becoming glass rich and not fusing.
They will all work best if you can dry the naturally absorbed water out of the nylon first. How to do that best depends on a number of variables.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
You cannot do nylon by a soldering iron. It degrades quite quickly at its melting point when in contact with air and even more so if it has absorbed water, which it does fairly quickly on exposure to normal air.
Pat
for site rules
Chris DeArmitt - PhD FRSC CChem
Plastic & Additives Webinars
Instant Downloads & Inexpensive
www.plastictraining.com
