Special Motor's Data
On a special EX canned pump Motor ,
I Found some data on the motor's name plate which is
not clear for me such as :
PN = 50 & tE = 12 s
Any body knows the meaning of these ratings ?
Thank you for you help ,
RE: Special Motor's Data
PN 50= rated for 50 Bar working pressure
tE= the max.allowable locked rotor time at rated voltage. Applied to Exe -increase safety motor construction.
