How To Be Piping Engineer
hei All, Now i study in Applied of Physics. There are learning about all kinds of applied of physics. Can you give me some advise how i can be piping engineer..
Thanks..
Thanks..
RE: How To Be Piping Engineer
You should consider changing your field of study to a recognized and accredited mechanical engineering degree program. Pay particular attention to fluid mechanics and beam theory. Purchase and study L. C. Peng's book. Then, probably most importantly, upon graduation, see if you can find a job or opportunity to work with a piping designer (not an engineer, but a person who draws and lays pipe out for a living) for a while.
My experience is that it is easier to be a good piping engineer when you have worked with good piping designers who already know what works and what doesn't.
What would you be doing, if you knew that you could not fail?
Can I just focus study in fluid mechanics and beam theory without change my field of study?
The road to becoming a true engineer, recognized and ultimately accredited as such, will be much easier if you start by getting an engineering degree. There are other avenues towards that goal but I don't know of any success stories of people going down those paths.
