Stress on rectangular plate
How do you calculate stress on a rectangular plate fixed on two opposite ends and simply supported on other 2 ends for tension and moment at center
RE: Stress on rectangular plate
You either use FEM or some closed form solution, from structural formulae handbooks. It is difficult to direct you to one precise answer not knowing how the force and moment are applied.
