Edit Material name
Edit Material name
Edit Material name
we use the new xml material database.
The file is shared and set in customer default.
Now, some material name are changed following some standard changing.
I'm not able to edit the matarial name via standard NX command, but only via Notpad ++ software.
it's correct ?
I set the update material information on open file, but the name is the same as before.
This option work only for mechanical value or also for the material name ?
Thank you...
Using NX 8 and TC8.3
