ProE double dimension in drawing
How do you add a parametric dimension note &dxxx to a table without the system automatically removing the paramtric dimension shown in the view with the same dimension?
For example I want to show the same dimension in the field of the part view as well as in a note.
RE: ProE double dimension in drawing
The best you can do is create a parameter pointing to the original dimension internal parameter, then use your parameter in the table.
Ben Loosli
