TFT-LCD for Car Navigation
What is the best digital TFT-LCD (6-bit RGB), 6.5" diagonal size for car navigation that would fit an operating temperature of -10 to +60 degree C? Is there an analog TFT-LCD in car navigation systems? Would a 0 to +60 degree C LCD be operational in climatic conditions of Europe, US, Japan, and in countries where climatic conditions ranges from -10 ~ +60 degree C?
RE: TFT-LCD for Car Navigation
umm, i am not sure what are the exact dimensions of the LCD display you want, but this may be close to what you are looking for.
- It is has an  input system of 16-bit RGB (6 bit video digital input) , it has 384 000 pixels per RGB dots which is preety good, the dimensions are 157.2mmx89.2mmx8.4mm. I beleive it passes your temperature criteria. This one i saw a wile back at www.sharp-world.com.
