Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...thank you for the wonderful resource that you have enabled here. It is clear, concise, well maintained and most importantly, helpful..."
Geography
Jimmyvanskip (Mechanical)
11 May 12 8:49
Does anyone have an accurate methodology for calculating the steam loss through a leaking PSV. I'm aware of the method using the length of steam plume where loss (kg/hr)= 2.8*6^L, but this is hardle an accurate method. Any other suggestions much appreciated.
don1980 (Chemical)
11 May 12 12:16
Jimmy - there's no accurate way to do that.
If you have any significan leakage through a steam PSV, or any other type valve, the only thing you can know for sure is that it will progressively get worse. Steam leaks slowly cut away at the valve seat.
Plan to pull the PSV for repair.
Close Box
Join Eng-Tips® Today!
Join Us             Close
