Can you identify the cause of this type of weld crack?
can you help me to identify the cause of this weld crack?(see photo attached)
thank you in advance
RE: Can you identify the cause of this type of weld crack?
Your attachments are not showing...try again.
Possible problem with the page... not the attempt...
Dik
You might want to re-post in the "Welding" forum??
