Detail with pilot hole to Assembly to Installation holes requirements?
I have a detail part with 4 pilot holes .128-.132dia with a pattern location of .0560M|A|B|C and hole to hole of .0140M|A. The bracket detail will be installed on the 2 longerons assembly upper and lower as shown in the picture. ME want the 2 hole to be pre-drill with .128-.132 on the longerons assembly upper and lower. The longeron upper and lower will be install to the skin using 4 pilot holes of .1280-.1320dia with a pattern location of .0140M|A|B|C. The bracket will then be drill full size drill .1640-.167 prior to fastener installation 5/32dia. What tolerance should I use at the longeron assemby? How do I ensure that the bracket holes will always matches at the installation? What step should I take to approach this problem? I am thinking to use same positional tolerance as the detail bracket.
RE: Detail with pilot hole to Assembly to Installation holes requirements?
Picture didn't get attached. But a quick read of your question makes me think that "virtual condition" will be an important part of the answer.
John-Paul Belanger
Geometric Learning Systems
http://www.gdtseminars.com
Hi Belanger,
How do you add picture in the attachment. When I click on attachment below nothing happen? I am reading about virtual condition and I have found 2 the virtual size of the pilot hole to be one to be .128+.0140=.142 for hole to hole and perpendiculariy relative to datum A and .128+.054=.182 positional tolerance relative to datum A|B|C. What should I do with this number?
You're right -- it looks like they've changed the format for posting replies. It used to have a different "look." I'm not sure how to attach!
For holes, the virtual condition is a subtractive formula, so it's not .128+.0140 but rather .128-.0140= .114 and the other one would be .128-.054= .074. But there's a lot of info in the original question and I'm not quite able to digest it all :)
John-Paul Belanger
Attached is a picture of the assembly I was referring on my original post. Detail part is release and I am working on assembly.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
The holes from the channel will be match drill on the assembly. Using the 2 Da holes on the top assembly and 2 Da holes on the bottom assembly. How to make sure that the holes pattern from the detail will matches on the assembly?
John-Paul Belanger
