Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just to let you know...what a great site you have. I posted a pretty generic question yesterday and have had 8 responses already, anyway thanks again and keep up the good work..."
Geography
tcnv (Civil/Environmental)
10 May 12 17:47
Are there published guidelines or recommended practices or procedures for how to remove an internal floating roof from an existing tank with a fixed roof? Also, should we be concerned with affecting structural integrity of the tank by removing the floating roof?
JStephen (Mechanical)
10 May 12 17:53
API has a number of Recommended Practices, which include things like hot work and working under floating roofs, and those should be reviewed as needed. Generally, it wouldn't be any harder to remove a floating roof than to do other repairs in the tank.
The floating roof is not normally considered to add any stability to the tank itself, so there would not be an issue there. One thing to check is that without the floating roof limiting the fill depth, it may be possible to fill the tank to depths for which it was not designed.
Presumably, you have looked at operational and emissions aspects already.
Duwe6 (Industrial)
11 May 12 16:50
Actual removal process is simple, but pricey
Empty and clean tank, and top & bottom of floater, and all floater compartments [if any].
Cut a 'Door Sheet' big enough to 'stab' a small crane through, about 7-ft high x 10-ft wide.
* CAREFULLY* burn drain holes in all tubular 'landing legs' that for the floater, and any tubular roof supports. Cl;ean up the effluent [if any]
Start cutting
Simple
6 Jul 12 13:15
Thanks JStephen and Duwe6. Tank will be used again, so would rather not cut hole in side. Which API Stds or guidelines specifically should be reviewed?
Duwe6 (Industrial)
10 Jul 12 15:29
Review API-653. Cutting out a "Door Sheet" entry is actually simple [for experienced tank builders] and is the industry standard for performing major work in a tank. This will not be a Do-it-Yourself project, sorry if I gave that impression. Get any reputable Tank Erection firm. With experience, this will be simple for them.
MJCronin (Mechanical)
13 Jul 12 10:23
Why are you making this change and what kind of roof will the tank eventually have ?
15 Aug 12 12:04
MJCronin- tank to be converted from oil storage to industrial wastewater storage. Floating roof ro be removed due to concerns with ice when converted to water storage. Tank already has a fixed roof in addition to internal floating roof.
PieterStander (Petroleum)
10 Jan 13 6:18
I am not sure how far you are in this process, however it should be relatively simple to remove the old roof. Most IFR's are assembled inside the tank and use the existing inspection hatch in order for the roof pieces to be carried in. After cleaning and degassing, you should be able dis assemble the roof again, i guess the only major obstacle will be to roll the sheeting up again as small as possible.
We have recently installed 7 IFR's into existing tanks with out any cutting of the tank, everything fitted through the inspection hatches.
www.dlm.co.za: Over Pressure Protection; Flow, Level & Density Measurement; Automation and Control.
www.metermatic.co.za: Electronic Presets; Additive Systems.
Close Box
Join Eng-Tips® Today!
Join Us             Close
