Solve problem with *inital conditions command
Hi everybody, I always used the command *initial conditions to import a predefined stress inside a sample to another one with same geometry and mesh. It always worked. today I don't know why it tells me: ***ERROR: Unknown global id: 60101 in instance: PART-1-MESH-1-1
Now, if I eliminate the command *initial conditions the analysis goes on perfeclty, but if a insert the command it's not working anymore. I checked the command line and the syntax is perfect (I just copied it from a previous working files).
Anyone has found this bug?
Thanks!
Thanks!
RE: Solve problem with *inital conditions command
You may have done this already but double/triple-check the node set that you are using in your *initial conditions. Is the node set defined in the new INP?
