PT Ratio Meaning
PT Ratio Meaning
Kind sirs,
Please englighten me with this issue.
We are using PT with Ratio: 13.8 kV/3R/110V/3R/110V/3V
What does this mean?
Thank you in advance and sorry for the ignorance.
RE: PT Ratio Meaning
see http://eng-tips.com/viewthread.cfm?qid=321282 for more on PTs with similar markings.
I believe the consensus was that the divide by 3 winding was to be feeding a 59N relay, used as a ground (earth) over voltage relay.
Do you have schematics to confirm that this is what is connected to the PT?
Correct...110/3V winding would be connected in a broken delta configuration and used for zero-sequence voltage detection.
thank you for the insight sir. i will try to upload the diagram for the connections.
scottf,
sir i believe both you and smallgreek are correct on this. thank you for your time.
As far as nameplate data requirements are concerned, is there something new in relevant standards that calls for this? I don't recall seeing that in North American standards.
@NorEE-
You are welcome! Please post a picture of nameplate, if you can.
No, this is normally seen in IEC applications.
IEEE VTs would normally use a 120V rated secondary or 69/67V rated secondary.
sir sorry for the late reply.
For now i can only provide a connection diagram as the plant is currently running and their are no provisions to take pictures of VT nameplates. ^^
