CIP concrete over new brick connection
I have a condition where a 4 wythe brick smoke stack, aprox.  6'x6'x5' high, is to be capped with cast in place concrete ring and aluminum/SS cap. I am thinking about the connection of new brick and new concrete. I want to avoid drilling dowels into the new brick (as the arch currently shows on the attached detail). Are there any products available for a connection like this, I mean something that can be embedded within the joints to make the connection?
Thanks.
RE: CIP concrete over new brick connection
You could use flats, say 1.5" x 3/16 in the brick joint, projecting into the cast-in-place concrete.
BA
What the heck is that chimney for, a blast furnace?  Why not cast the whole thing, and just put a brick veneer outer layer, on a cast conc. brick ledge and up under a 7-8" overhanging, conc. outer lip at the cap.  Cast a water drip reglet 3/4" back from the outer edge of the cap, all around, on the underside of the overhanging conc. outer lip.
Brick tends to expand, while conc. tends to contract with time, so all-in-all keying them together may not be a real good idea.  Maybe a case could be made for putting a through wall flashing on top of the brick, with a drip edge, and casting the cap on top of that flashing.  Where is that cap going to go?  Cast a retainer ring on the inside of the conc. cap.  Put a 1x2 strippable form board against the brick on the inside of the chimney and cast the cap 2" lower than the top of the brick on the inside.  Then, pull the form board, just a retaining ring is left.
You could also have some problems with that 4 wythe brick wall and moisture and heat on the inside and cold on the outer surface.
If it is only 5' high and 6' square, I don't think any sort of connection is required.  The layers of brick are only connected with mortar, so why isn't just casting the concrete on the top layer of brick sufficient?
@dhengr: The chimney is an architectural feature, so its not going to be used.
Then you can probably do anything you want
