Trigger Coil Unstable Waveform Issue
Hi All,
Right now I have a problem with my trigger coil product which is used for flash lamp. It's show unstable waveform when electrical test is performed. I need your kind help to suggest me the root causes may effect to the problem issue.
Below is the specification one of Trigger Coil Model
ZS 1052 (H)
Specifications:
Trigger Energy
10 mJ
Trigger Power
0.5 Watt
Primary Inductance
20 uH
Transformer Ratio
1:36
Primary Voltage
300 Volts
Secondary Voltage
11 kV
Thank You,
ZS 1052 (H)
Specifications:
Trigger Energy
10 mJ
Trigger Power
0.5 Watt
Primary Inductance
20 uH
Transformer Ratio
1:36
Primary Voltage
300 Volts
Secondary Voltage
11 kV
Thank You,
