How to design a concrete collar between existing and new concrete pipe
I'm trying to find information on how to design a concrete collar. This collar will be used to connect an existing concrete box culvert with approximate dimensions of 5'x5' to a new concrete pipe which will have an inside diameter of 48" and outside diameter of 4"-10". My design now calls for a 10" thick concrete collar which is 48" inches long...24" on each side of both the pipes. The collar has #5 bars spaced 12" O.C. in both directions. Also, I'm calling for #4 dowels epoxy grouted in four locations in both the existing pipe and also the new pipe. Does this design sound reasonable?
RE: How to design a concrete collar between existing and new concrete pipe
BA
Perhaps if the poster could attach a sketch?
Richard A. Cornelius, P.E.
WWW.amlinereast.com
BA
