Exporting a ISO view
I am trying to export any drawing from Mechanical Desktop into Flash MX. I need the drawing to be in a vector format so that rules out any type of photo file. Since I draw in 3D a wmf file exports all the lines in the drawing which does not help. Is there any way i can export just the lines required for a ISO or 2D view? Or a way to convert the drawings you get automaticly in layout into lines that i could copy over? Any idea will help greatly. Thanks.
RE: Exporting a ISO view
Dear jveland,
The AMVIEWOUT command is the key of your problem.
Farzad
