Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It is good to know that there are groups such as this willing to share knowledge in this money driven economy..."
Geography
perruolo (Petroleum)
8 May 12 16:34
Gents
I wonder how to interpret the changes on the essentials variables which require the requalification of the WPS. For instance: Statements like "Major increase" of flow rate; An "Increase" of time between passes; A "change" in the speed travel; A "decrease" of the minimum pre heat temperature. It is not specified a value. When should I consider a major change????? If time between passes "Increase" 1 seg, or the Pre-heat temp "decrease" 1°C should the WPS be requalified?? of course I am exaggerating.
I appreciate any suggestion
Miguel
SectionIX (Petroleum)
9 May 12 6:05
PRCI published a document where their interpretation of a major increase in flow rate was +/- 20 % was considered reasonable.
An increase in time between completion of root and start of hot pass should be self explanatory.
For travel speed, their interpretation was that the travel speed shown on the WPS should be no more than +/- 20 % from the median recorded PQR value. The specified range should reflect the minimum and maximum values that produce an acceptable weld.
For decrease in preheat, if you can measure a one degree difference.....
9 May 12 7:53
AsmeIX Thanks for your reply. Where can I get the document you make reference???
9 May 12 8:24
Contact PRCI at http://www.prci.org/.
Ask for Guidelines for Interpretation and Application of API 1104.
Its pricy; $400.00 for non-members
Close Box
Join Eng-Tips® Today!
Join Us             Close
