Who can make this? I will pay $$$.
Although I understand electronics, I must seek help with my project. If anyone is willing to do some bench time to help me on this, compensation will be made.
I need 6 devices in all. I know the technology is already out there to make them but I do not have the knowledge to make them.
Device #1 - sensor to be attached to the end of a 2' pendulum to measure the range and rate of motion. Data will be transmitted to device #4 which will be less than 3' away.
Device #2 - sensor will measure the rate of motion regardless of direction of motion or attitude of the sensor. Data will be transmitted to device #4 which will be less than 3' away.
Device #3 - sensor will count puffs of air passing across the sensor and report them in a "per minute" ratio. Data will be transmitted to device #4 which will be less than 3' away.
Device #4 - receiver/transmitter will receive signals from devices the first 3 sensors and relay the data to device #5 which may be up to 100' away and will NOT be in the line of sight. If this device is compatable with a wireless network, device #5 will not be needed.
Device # 5 - receiver/transmitter will be connected to a PC. Data received from device #4 will be exported to a program running on the PC awaiting the data. It will also take instruction from the program and transmit a signal to device #6. Device #6 will NOT be in the line of site and may be up to 100' away.
Device #6 - receiver/transmitter will translate the instructions from the program and send an IR signal to an "off the shelf" DVD player that WILL be in line of site.
That's what I need. Is anyone willing to help?
RE: Who can make this? I will pay $$$.
