Mass Properties in BOM
I am using Mechanical Desktop 2005.  When I go to "Assembly", "Analyst", "Mass Properties", and add a material to my parts:  When I click "Calculate" on the "Results" tab, the "Mass" is correct.  However, when I insert my BOM on to my title block in Layout, the "Mass" column always shows "1.000".  It never shows what is shone "Results" under "Assembly Mass Properties".  Is this an error in the program, or is there a variable I need to change?  Thank you for your replies!!!!
