Excel ERIC - Emission Reduction Investment Curve
RE: Excel ERIC - Emission Reduction Investment Curve
Please see the attached file.
Issue 1: I want to use a logarithmic chart, but I use the logarithmic chart, I lose the vertical lines.
Issue 2: I want to plot the cumulative IRR in the same chart (as in the one picture I attached before), but I don't know how can I add another curve on the same graph.
Ali
Quote (alishaikhji)
Did you try reading the error message?. You're trying to plot down to 0, which doesn't exist on a logarithmic axis. Change the lower y values to 1 instead.
Quote (alishaikhji)
Um... the same way you added the 2nd curve? And the 3rd, 4th, 5th, 6th and indeed, the 11th additional curve? I think you need to do a bit of experimenting first or be a bit clearer about where you're getting stuck.
