nut size info needed
Could somebody tell me what is the width across the flats for 15/16-20 UNEF nut? I can't find this info anywhere. It would also help if somebody suggested the place to buy this nut. Preferred material is plastic, but it could be steel or aluminum, too.
Thnks in advance.
Efraim G.
Thnks in advance.
Efraim G.
RE: nut size info needed
Looks to be 1.25 inches or 31.8mm across the flats.
"The attempt and not the deed confounds us."
Efraim
gjb
