18 volts throigh a 12 dc motor
18 volts dc through a 12 volt dc motor. the motor operates a hydraulic pump. no electronics other than a coil relay to close the motor circuit.  i would still just wire the relay 12 volts. Whole thing is to operate a 1 inch bore RAM. 1000lbs pushing capacity.  I'm hoping to speed it up a bit. Operates 1 minute max then a few  off. Only about 10 cycles per hour, an hour a day. Currently uses a rep cycle rv battery.  Looking to replace it with 3 - 6 volt instead.  Thoughts?
RE: 18 volts throigh a 12 dc motor
Just wondering how long it will take your motor to overheat! not very long by the sounds of it.
My advice buy a motor to do the job.
Thanks desertfox. I understand it would generate more heat.  My question was more whether the small over voltage would create too much heat given the short run time and very low duty cycle. A larger motor is not really an affordable alternative because the pump and motor are one assembly. The motor is designed for 100% duty cycle so I thought this intermitent use at overvoltage might be perfectly acceptable.
Greg
Seems like you've entered the realm of trial and (hopefully no) error.
P.S.: A 50% increase in voltage may not be a 'small' amount.
How long do you want it to work. Is it for a specific job, or will it be working like this for an extended time?
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
I think stopping and starting is the problem running continuously at  normal voltage is okay.
Get some advice from your electrical department i think they will advise no.
It isn't just the voltage on the DC motor that you have to worry about.  The over-voltage will allow the motor to draw more current.  That's what's going to heat you up and burn you out.  Imagine a starter motor for your car.  They are rated for 12V, but their duty cycle is very low.  If you run it at 12V for a minute you better look for a new starter.  However, you could most likely run the same motor indefinitely at 3V.  I think Walterke has it right.  This may be a bit of trial and error.  Maybe you could hook up a potentiometer to dial up the power as needed?
Dan
www.eltronresearch.com
Dan's Blog
" I'm hoping to speed it up a bit."
If the ram operates for a significant portion of its stroke with little or no load, then you might look into getting a two-speed hydraulic pump.  Alternatively, have two motors, the new one running a high-flow, low-pressure pump, although you need a bit more plumbing and/or control logic to operate it.
50% over is NOT small.  Hey, what do you have to lose.  Try it and see if it works.  Worse case scenario, you go back to 12V and/or buy a new motor!!  I am always big on "experimenting"!!
Let us know....
Even though it is "an hour a day", it is still 10 starts per hour.  The "starting" action, with it's inrush current, does all the damage.  If you goose it with +50% voltage, 10X per hour, expect failure over time.  Motors are designed for steady state operation.  You upsize the motors (more thermal mass for heat dissipation) for multiple starts/hour.  I assume you do not have any definitive info from the manufacturer about higher voltage operation and acceptable quantity of starts/hour.
You could always just try it and see how long it lasts.
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
The time savings won't be enough to warrant "trial by smoke".  If I had gotten a concenses here that given the duty cycle / application it wouldn't be a problem I would have gone ahead but obviously there are two many variables.  I suspect, given the mass of the motor and the industrial application of it's first purpose, that it would propably be fine but given the feedback I will leave well enough alone.  :) Thanks for the feedback.
would it be possible to start the motor at 12V and then gradually increase it to 18V? Might reduce some of your problems.
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
