Basic dimension question
Hi All:
A simple question of basic dimension, when we calculate the position we need to measure the actual dimension 2X .185 as shown on the attached print, it's a true position of the feature (although I know there is a basic angle 2X 50°), shall we change it to basic dimension?
Thanks for your inputs
SeasonLee
SeasonLee
RE: Basic dimension question
My proposal would be to switch .185 to basic, show 2 of them on both sides of the part and apply two separate profile of surface callouts to both flat surfaces.
Frank
The print is per ASME standard, I agree surface profile control is better than position.
SeasonLee
SeasonLee
2) If you intend to locate the centerplane the dimension should relfect that intent (bad form).
Frank
Didn't you post this sketch or similar some time ago here and the same question was already answered?
SeasonLee
Yesterday, I got a different picture than this one.
Frank
Frank
The sketch posted yesterday is same as what I posted at 3-20-12, sorry for any inconvenience caused.
http://www.eng-tips.com/viewthread.cfm?qid=318331
SeasonLee
