Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It is good to know that there are groups such as this willing to share knowledge in this money driven economy..."
Geography
AngelM (Mechanical)
7 May 12 3:13
Pressure: 2 bar
shaft size: 55mm
rpm: 1500
Should be used a metal bellow seal?
Double seal or simple with quench?
Elastomers? Viton is Ok or it is too tight?
gyaneshwarp (Electrical)
7 May 12 22:52
1. If cost is not consideration, metal bellow seal will be better. It avoids dynamic elastomer. API Plan 11, 62.
2. Pusher type seal with viton elastomer also will be OK. If pump has jacket cooling Plan 02, 52 will be OK.
AngelM (Mechanical)
8 May 12 2:24
Plan 62 with steam water?
Regarding the plan 52, with barrier fluid would be appropiate? The same oil to low temperature?
flexibox (Mechanical)
13 May 12 16:21
You should use single high temp metal bellows with API plan 02 & 62 (LP steam or N2. Using pusher seals is on the border line for viton buy you can use perfluoroelastomers. Plan 02 because VP should be very low. plan 62 to stop coking.
Close Box
Join Eng-Tips® Today!
Join Us             Close
