Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...thank you for the wonderful resource that you have enabled here. It is clear, concise, well maintained and most importantly, helpful..."
Geography
RFreund (Structural)
6 May 12 18:59
Any suggestions for a slope stability software that would be used primarily for checking global stability of geosynthetic reinforced retaining walls. Preferably something that is easy to use/user friendly. I have used GSlope which seems to be a fairly user friendly program. Seemed slightly dated (atleast the version I used).
Thanks in advance!
EIT
www.HowToEngineer.com
FixedEarth (Geotechnical)
27 May 12 22:59
For the features it has and its cost, I like the GEO5 slope program by Fine software.
29 May 12 7:58
FixedEarth - Have you used GSlope http://www.mitresoftware.com/prod01.htm or Reesa http://www.reslope.com/ressaindex.htm ?
EIT
29 May 12 11:36
No, I have not tried either software (No Demo's).
I am also on the market for a slope stability software. With the GEO5, I am able to evaluate their capability with a DEMO. It can do tiebacks, geogrids and strip loads on terraced slopes, so I am leading towards it. However, I probably would delay the purchase until I have a slope stability project that would pay for it. It is also under $1k.
29 May 12 12:57
FixedEarth - Good to know, thank you. We seem to be in a similar situation.
EIT
JML4TCM (Civil/Environmental)
26 Jun 12 17:33
ReSSA and MSEW by ADAMA Engineering.
www.geoprograms.com
GeoPaveTraffic (Geotechnical)
28 Jun 12 10:13
I prefer UTEXAS4 available from Shinok software. It may not be as user friendly as some of the others, but I prefer the detailed output information and input method.
This may sound counter intuitive, but I believe that modeling software shouldn't be too easy to use. Otherwise people start using it without enough thought. This leads to the age old problem of garbage in and garbage out.
I believe that global stability should be performed by an experienced geotechnical engineer. Input parameters (soil, water, weights, etc.) for slope stability are not easy to determine and are influced by many variables.
Mike Lambert
Close Box
Join Eng-Tips® Today!
Join Us             Close
