Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...My thanks to the contributors who freely share their knowledge and enthusiasms. This forum restores some measure of my faith in human nature..."
Geography
Santo928 (Mechanical)
5 May 12 19:58
Need info on drill type, speed, pilot size drill for a 3/4 in. Hole drilled through a flange at 90 deg. To flange face for a pressure tap. Thickness of flange is 6 in. Concern about chips and wear on drill. Also suggest coolant type and rate.
MikeHalloran (Mechanical)
5 May 12 21:51
Do you need a hole that big just to sense the pressure?
Mike Halloran
Pembroke Pines, FL, USA
Helpful Member!  saberblue (Industrial)
6 May 12 13:48
How many of these holes and on what type of machine? Are there any other parameters that you are concerned about?
Helpful Member!  arlieb (Industrial)
31 May 12 7:22
Here is what I would use.
Drill Kennametal Dynapoint with thru coolant. Kennametal Catalog # K210A07500HP
Speed / Feed 270 SFM and .010 IPR
This Sir is all you will need for tooling. Do not spot drill for the hole just drill it.
Close Box
Join Eng-Tips® Today!
Join Us             Close
