Catia V20 Hide Show
Catia V20 Hide Show
Catia V20 Hide Show
Hi All,
The hide show command works on a the entire part in V20, until you make it the work part and then you may hide/show individual items.  V18 was able to assign say, F2 to hide/show a single item anywhere in an assemble.
Jim
RE: Catia V20 Hide Show
Hello kuleszajmk,
In V20 Hide/Show command works as in the previous releases.
Most propably the [Products selection] command in the [Filter Selection] toolbat is activated and due to this you are unable to select features of a product.
I hope it helps
-GEL
