Strain gauges and typical millistrain
Im trying to test a signal conditioing circuit for a strain gauge bridge full bride setup. I am going test the circuit with two ac signal inputs to replicate the bridge voltage. Can anyone tell me typical ranges of millistrain so I can change the values of the four resistors to set the bridge voltages?
Apparently it ranges only in a few millistrains.
I am using four 350ohm strain gauges.
RE: Strain gauges and typical millistrain
A commercial force transducer might put out 2.5 mV/V at rated max load.  If it's using 2 active gages then that works out to a strain of .0025.
