Catia sketcher symmetry issue
Hello, i made a square and want to make it symmetric by origin axes, when i apply symmetry constraint the square is throwed away from the axes, i attached a picture to see what is happening.
I use Catia V5 R20
I use Catia V5 R20
RE: Catia sketcher symmetry issue
How big is your avi file ? Not everybody has a cheap and good connection...
Fernando
Symmetry command is in Transformations toolbar.
Fernando
http://www.youtube.com/watch?v=nHn5gacqdLw
Fernando
Multiselect (hold ctrl) and pick first the left vertical lines of the square, then pick the right vertical line of the square and finally the sketch axis then go to constraint function and set symmetry .
