Zero stiffness error of a simply-supported beam
Hello there,
I'm new here and this is my first post
I'm majoring in structural engineering and I need help in SAP2000.
I'm using SAP2000 Educational Version 7.10.
So I was practicing and created a simply-supported beam with a span of 6m and having uniformly distributed of 5 kN/m and concentrated load at x=3m of 10 kN/m
I assigned the frame section and material and when I did a minimized run, it gave me an error of "zero stiffness found during solution for DOF RX of joint 3 at x=6" and the structure was considered unstable and analysis was terminated.
I know my question is from the basics but I couldn't find anything related to this.
Many thanks in advance.
RE: Zero stiffness error of a simply-supported beam
