AISC Vertical Bracing Design Guide
Does anyone have information on when the AISC Design Guide for Vertical Bracing, authored by Dr. Thornton and Larry Muir will be available?
It's no trick to get the answers when you have all the data. The trick is to get the answers when you only have half the data and half that is wrong and you don't know which half - LORD KELVIN
RE: AISC Vertical Bracing Design Guide
No release date set.  Still being reviewed.  Should be this year.
