Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...A lot of the information I've found at this site would've taken me forever if I'd have attempted to research it on my own. Thanks again."
Geography
RobertCT (Mechanical)
4 May 12 14:02
Hello all!
I'm working on a problem where I need to determine reaction loads based on a imposed displacement of a system.
I have a component (that can be approximated as a long beam) that will  be forced to bend (elastically) by brackets supporting it at various locations, I know how much each bracket / support will move (this displacement is imposed by the circumstances of the problem). I need to be able to determine the reaction loads in each of the brackets at this specific displacement.
Is there any way I can run an analysis in FEMAP where instead of imposing loads, i can impose a final deflected shape and have the analysis give  me the required loads at specific locations /nodes?
Thanks.
BlasMolero (Mechanical)
6 May 12 5:34
Dear Robert,
Oh yes, you can prescribe an enforced displacement using "Model > Load > Nodal > Displacement". But in order to run the analysis you have to prescribe a displacement constraint "Model > Constraint > Nodal" to the same node with the same DOF as you used to prescribe the enforced displacement, if not the NX NASTRAN solver will give you error, OK?.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
rb1957 (Aerospace)
7 May 12 8:27
try a simple test case to make sure you're doing it right
7 May 12 9:29
I should have clarified, I use NEI Nastran, will this be an issue?
ThomasH (Structural)
7 May 12 9:59
Hi
It's the same approach in NEiNastran.
You constrain the node and than you enforce a displacement on the constrained node.
Good Luck
Thomas
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
