How do you import a v4 export file via command line
Hi every one this is a balst from the past
Does any one know the way to import catia export files via the command shell, would be greatly apprecited.
Cheers
JY1973
Cheers
JY1973
RE: How do you import a v4 export file via command line
Did you tried http://ww
Fernando
There deosnt seem to be anything thing there thought i had the correct syntax with catutil -XM -l catimp and having the catimp.in file correct but no joy.
JY1973
