Maximum Switching Surge Factor Calculation
I'm trying to find the calculation for determining the Maximum Switching Surge Factor for a 230kV Transmission Line.
This term is defined in the National Electric Safety Code as a switching-surge level for circuit breakers corresponding to 98% probability that the maximum switching surge generated per breaker operation does not exceed this surge level, or the maximum anticipated switching-surge level generated by other means, whichever is greater.
Anyone familiar with a methodology or calculation for coming up with this value??
RE: Maximum Switching Surge Factor Calculation
Sorry,I cannot find anywhere in NESC where "Maximum Switching Surge Factor" is defined. Could you pls. indicate the chapter no.?
Section 232D3a
(In the 2011 edition of NESC it is on page 93 about 2/3 of the way down the page.)
