Dimensioning to bored hole that has a fillet at the bottom.
When calling out the depth of a hole, or counterbore that has a flat bottom and a small fillet radius at the bottom of the hole, does the depth refer to the full diameter or to the very flat bottom of the hole? ASME Y14.5-2009 seems to picture it on page 17, Fig. 1-38, but it is not clear as to what the dimension leader line is going to.
RE: Dimensioning to bored hole that has a fillet at the bottom.
In the text in -1994 version, section 1.8.9, it's pretty explicit about the depth dimension of a blind hole being the depth of the full diameter form the outer surface of the part.
Of course, if the dept is unclear it also says to directly dimension it.
If you don't get a satisfactory answer here consider looking in forum1103: Drafting Standards, GD&T & Tolerance Analysis.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
The ASME Y14.5 standard assumes you are drilling the hole, and that there will a 118° cone at the bottom. Since you are not doing this, the ASME standard does not help you.
Do a section view, and explicitly show the depth and radii.
This question belongs in forum1103: Drafting Standards, GD&T & Tolerance Analysis.
You could try and extrapolate, both from what it says about round holes and the analogy to what it says about counter drilled holes, and conclude that the dimension would apply to the full diameter portion.
However, as there's room for misunderstanding I'd look to directly dimension in a section as you say.
Do you have the -2009 standard drawoh? Do you see the figure the OP mentions showing small fillet rad at the bottom of a hole?
ASME Y14.5-2009 Figure 1-36 shows a set of holes with depths specified. All the blind ones show a cone. I don't any changes from Figure 1-34 in ASME Y14.5M-1994. This makes sense. If I specify a blind hole with a depth, it is a safe bet that the hole will be drilled.
Note how the drawings do not impose control over the bottom of the holes. The 118° cone is shown because the drafter anticipated drilling. If the holes were cast in place, the bottoms could just as easily be round, or flat with a fillet, as noted above. The depth specification indicates full diameter from the top surface down to the specified depth.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
I would most certainly make a section view and show both the radius and depth on it. We have these powerful CAD tools that make view creation easy - save everyone the time of researching an obscure interpretation of a standard and show what you want.
make sure the radii is tolerance to allow for clearance.
Mfgenggear
Cockroach
