Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...These forums are an excellent source and example of the way people can help each other..."
Geography
spggodd (Mechanical)
4 May 12 6:49
I am currently working for a large engineering business as a Mechanical Designer.
Recently a friend has come to see me and ended up chatting about a piece of equipment he is having trouble with during his work and was thinking about designing and building his own.
He then mentioned that I would have more experinece coming up with the detailed engineering designs.
My question is, how common is this throughout the engineering sector?
Is is generally acceptable to take on extra work like this in my own time?
Do I need to set up my own company in order to start doing this?
If any of you have experience with this sort of situation I would be grateful if you could share your experiences.
Many Thanks
Spggodd
slta (Structural)
4 May 12 7:18
I started my own company while working for another (part time).  I was upfront about it, made it clear that the two would be separate time-wise, and because the work was totally different, they were fine with it.
Make sure you talk to your boss and/or the dreaded HR, to ensure there aren't any conflicts of interest.  And definitely set up your own company - it takes a bit of work up front but can save you from personal liability down the road.
Good luck!
IRstuff (Aerospace)
4 May 12 10:31
> Make sure you get written OK from company
> Bear in mind that many states will require you to have a PE license if you are offering "engineer" or "consulting" services.  There many be loopholes in the way your company is named that you'd need to explore.
TTFN
MiketheEngineer (Structural)
4 May 12 11:13
Just be up front - make sure there are no "clashes".  Some states are very adamant about this!!  and so are some employers!!
Helpful Member!  TheTick (Mechanical)
4 May 12 11:13
These are the kind of loopholes that will stretch your neck.  My state's code is very specific about what constitutes engineering activity, regardless of whether you call yourself "Bob's Engineering" or "Milt's Ice Cream Soda Emporium".
4 May 12 11:16
Thanks for your advice, im actually based in the UK so I guess the law could be different.
KENAT (Mechanical)
4 May 12 11:22
spggodd, yes the UK is a little less uptight about such matters but you may still want to double check any regulatory or liability concerns.
Do you have an employment contract, does is say anything about moonlighting or similar?
Are you looking at setting up some kind of consulting business, or is this more of an 'invention' kind of think with your associate?
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Close Box
Join Eng-Tips® Today!
Join Us             Close
