any recommended Tangent-delta tester?
I am working for a power plant electrical division. Recently insulation of a 5kV cable was failed, about two hundred kilo-ohm. Some expert said that we should try to use Tan-delta tester to diagnose other medium voltage cables.
Therefore I would like to ask did any one ever use friendly tan-delta tester? How much was it? Thank you.
RE: any recommended Tangent-delta tester?
I rented the unit from Intellirent, in Dallas, TX. I forget the price.
