DOL starting motor, 2 dif sized txf's
Quick question:
If you use a generator (say 750kVA) as a power supply, stepping up through a 500kVA transformer with around 5% impedance, then try to DOL start a 180kW SC motor hooked up to a fan. Will the generator see a significantly lower startup current than if a 1500kVA 5% impedance transformer is used?
RE: DOL starting motor, 2 dif sized txf's
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
I don't see many sophisticated breakers on a generator of that size. The breaker is probably a thermal magnetic which is tripping on instantaneous current.
The instantaneous (magnetic) trips may be set one notch higher.
Bill
"Why not the best?"
Jimmy Carter
the generator has to trip as the overload will be more than 80%[minimum,depends on voltage drop].
