Determine the grade of ductile iron
I have a steel tube with a ductile iron ring insert that is brazed in place with copper. Internal threads are cut into the ductile iron ring. I know the chemical composition of the ductile iron, but do not have enough of the material to perform a mechanical test of the material. The microstructure of the ductile iron is bainitic which I think indicates it is austempered (correct me if I'm wrong).
The chemical composition is low in Nickel, Iron, Mo, etc. So this leads me to believe this material is Grade 1 austempered ductile iron per ASTM A897. The iron insert is machined from bar stock.
Does anyone see a problem with this logic? THANKS!
RE: Determine the grade of ductile iron
