st3 hole position
st3 hole position
st3 hole position
st3
 When I try to position thread holes to a big subplate to match couterbores from parts attached to it, takes a lot of time as computer is writing to hard drive information for ich hole. Any help...
RE: st3 hole position
What is your computer spec. ?
Is this in a single part or are you working in a big assembly?
It sounds like you don't have enough memory in the computer and its using the hard disc virtual memory, hence the disc activity.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
It is a big assembly but if I try to do it in part it has no difference. It might be something with live rules. Even if I suspend live rules takes long time to add the hole or move something. can I turn live rules off.
Sorry, I never used sync mode so I've no idea what it could be, but post your computer spec just in case.
bc.
Quadro FX4600.
intel core quad2 2.66
nvidia Ge Force GTX 560 1.5gb
memory 8 gb
Sorry for the delay in replying - been really busy.
Your computer spec sound OK although I'm not sure about using a GeForce graphics card.
This isn't a card preferred for CAD so it could make a difference.
Other than that I can't really help.
Sorry.
bc.
Quadro FX4600.
