Testing a brushless generator
Can anyone describe how to test a brushless generator. Looking to test stator - no issues, PMG stator no issues, main excitor stator no issues. Will test diodes - no issues.
Just need to clarify the exact correct way to test the rotor. Would disconnecting the diodes & dc cables from the diode plate/IR testing from earth to cables be correct?
Assume to test main excitor/PMG rotor I'll need to IR from rotor other side of diode plate to earth testing both simultaneously?
Can anyone please confirm
RE: Testing a brushless generator
Sounds reasonable: just split it testable sections. For a small set I wouldn't go too high on the megger test voltage - 250V should be ample. Obviously check continuity too. wink
Before doing anything more I would just flash the rotor.  Sometimes they just use the residual.  I hate things that I can't explain but it just seems to work.
